| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59272 04/16/2006 5:58 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | While over hauling my Rochester Model B carberator,I knoticed that #7 power spring is missing and does not come in the rebuild kits.Dose it have to be there for the carberator to work properly? Referance Motors Auto Repair Manual sixteenth edition page 148 or Chevrolet Truck Shop Manual 1948 to 1951 models includes 1952 supplement page 6-63 Thanks Neal | | |
#59273 04/16/2006 8:13 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Beav,,I cant help you but maybe you can find something on this post.. carbking is our expert,you might pm him if you dont receive any help.. click here Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#59274 04/16/2006 9:41 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it,s the spring that goes behind the power piston it must be there. The easyest way to get one is to find another carb to use for parts. If not I think I have one cannibalized at the shop & will look tommorrow. Also make shure there is a passigeway in the base gasket for vacuum to reach the hole in the bottom of the carb. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#59275 04/17/2006 11:07 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I found that spring. If you still need it e-mail me an address & i,ll mail it to you. George [email protected] They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#59276 04/18/2006 8:38 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | George Could you explane how and what that power piston does, please? | | |
#59277 04/18/2006 9:33 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | carbking is named carbking for good reason as he is THE expert on carbs. You should click on the directory link above, search for carbking, then click on the link to his posts. You will find a gigantic wealth of information on the Rochester B. I distinctly recall an excellent detailed description of what the power piston does and how critical it is.
Better yet, you may get to the post I mentioned quicker by searching for power piston and then pick out the carbking posts.
Good luck!
Mike Barnes 1950 GMC 1-ton pickup
#59278 04/18/2006 11:41 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The power piston opens (extended) when there is low vacuum at the manifold port on the base of the carb. It offseats a little ball valve which bypasses the main jet allowing more fuel in the mixture through a drilled oriface. As vacuum comes back up, the valve retracts and lets the ball re-seat, leaning out the mixture for cruising. The power valve is absolutely necessary to get good fuel economy and have a drivable engine.
