5 members (DoubleB, EchoBravoSierra, frogfarmer, TooMany2count, Achipmunk), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#59272 04/16/2006 5:58 PM
While over hauling my Rochester Model B carberator,I knoticed that #7 power spring is missing and does not come in the rebuild kits.Dose it have to be there for the carberator to work properly? Referance Motors Auto Repair Manual sixteenth edition page 148 or Chevrolet Truck Shop Manual 1948 to 1951 models includes 1952 supplement page 6-63 Thanks Neal
Beav,,I cant help you but maybe you can find something on this post.. carbking is our expert,you might pm him if you dont receive any help..
click here
Redryder pix
My Hotrod
Riding in the Passing Lane
If it,s the spring that goes behind the power piston it must be there. The easyest way to get one is to find another carb to use for parts. If not I think I have one cannibalized at the shop & will look tommorrow. Also make shure there is a passigeway in the base gasket for vacuum to reach the hole in the bottom of the carb.
1972 Chevy c10 Cheyenne Super
#59275 04/17/2006 11:07 PM
I found that spring. If you still need it e-mail me an address & i,ll mail it to you. George
[email protected]
George Could you explane how and what that power piston does, please?
carbking is named carbking for good reason as he is THE expert on carbs. You should click on the directory link above, search for carbking, then click on the link to his posts. You will find a gigantic wealth of information on the Rochester B. I distinctly recall an excellent detailed description of what the power piston does and how critical it is.
Better yet, you may get to the post I mentioned quicker by searching for power piston and then pick out the carbking posts.
Good luck!
Mike Barnes
1950 GMC 1-ton pickup
#59278 04/18/2006 11:41 PM
The power piston opens (extended) when there is low vacuum at the manifold port on the base of the carb. It offseats a little ball valve which bypasses the main jet allowing more fuel in the mixture through a drilled oriface. As vacuum comes back up, the valve retracts and lets the ball re-seat, leaning out the mixture for cruising. The power valve is absolutely necessary to get good fuel economy and have a drivable engine.
Paint & Body Shop moderator
