1 members (Hotrod Lincoln), 92 guests, and 2 robots.
Topics128,132
Posts1,056,729
Members48,454
#591989 11/12/2009 10:13 PM
I have a 64 c10 in-cab tank and I can't get the sender gasket to seal for long.
First I tried Aviation Form-a-Gasket Sealant - lasted ~1 month then started seeping.
Second I tried Permatex #1 - lasted ~6 months and now it's seeping again.
I'm using the rubber gasket that came with the new sender. Is there some other gasket material that'll work better? Is there a better gasket sealer?
Tanks!
Terry
There is a product called Seal-All.That is for gas.That would do it.
It's odd however,my 52 uses a rubber gasket,and I didn't use sealant.No leaks.Humm Now you have me worried grin
Thanks! I'll try that. Maybe I should've not used any sealant in the first place.
I had similiar problems in my 54. I used seal-all and it has held for the past year. Also make sure your gas cap is venting. When your gas tank gets warm it builds up pressure and the pressure finds the weakest link. Which sounds like your gasket. Good luck. Hope this helps.
H Online: Content
Permatex Super 300 is a brush-on sealer that was developed to resist aviation gasoline. It's NOT the same stuff as the 3D brush-on liquid- - - -Super 300 is almost black while 3D is brown. A thin layer of Super 300, and a cork gasket if you can find or make one, should solve your problem. Most parts stores have sheet cork gasket material, and you can use your rubber gasket as a template to cut a cork one out.
I had the same problem in my '50. I had bought a new gascap. It was vented, but required a few pounds of pressure to vent. I drilled a hole in the vent. Now its fine!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
