1 members (baldeagle),
109
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | i'm putting my motor back together, crank in with .006 clearance and pushed to the front, but when i fit the front end plate and new thrust plate, the outside face of thrust plate isn't parallel/flush to the crank hub. it's approx a .06 too 'thick'. i even tried the old thrust and it's not much better. sand/file/grind it thinner? | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Are you talking about the camshaft thrust plate? As long as the timing gears line up right, and the cam end play is correct, I don't think the alignment of the thrust plate with the crank will be a concern. Maybe I'm not understanding what you're trying to align. Jerry
| | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | yes, the cam thrust plate. and i was wondering the same as you said as far as a line up. but by two books, it's face is supposed to be even with the crank hub. and since it isn't by the book, it makes me say 'hmmm' when i see the wear rub on the original thrust plate | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | If you change the thickness of the thrust plate, aren't you going to mess up the end play on the camshaft? I seem to remember there's a stepped-down area on the cam gear that prevents the gear from being pressed too far onto the cam and locking up the thrust plate. I could be mistaken, however. Ive been working with a Ford 302 V-8 lately, and a couple of stovebolts, and they've both got cam thrust plates. I know for sure the thrust plate on the Ford also sets the timing chain alignment and camshaft end play. Jerry
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The spacer ring (usually sold as a spacer ring/thrust plate set to control clearance) is chamfered on the I.D. on one side only and if installed upside down will not shoulder up against the journal properly.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | yeah, i thought about end play change, but since that's controlled by the spacer ring as curt said, it'd remain the same. the books show this checking being done before the cam gear is on the cam | | |
