4 members (Cosmo, dt235sd, Gray_Ghost, Gdads51), 84 guests, and 2 robots.
Topics128,060
Posts1,055,840
Members48,427
#592087 11/13/2009 4:23 AM
i'm putting my motor back together, crank in with .006 clearance and pushed to the front, but when i fit the front end plate and new thrust plate, the outside face of thrust plate isn't parallel/flush to the crank hub. it's approx a .06 too 'thick'. i even tried the old thrust and it's not much better. sand/file/grind it thinner?
Are you talking about the camshaft thrust plate? As long as the timing gears line up right, and the cam end play is correct, I don't think the alignment of the thrust plate with the crank will be a concern. Maybe I'm not understanding what you're trying to align.
yes, the cam thrust plate. and i was wondering the same as you said as far as a line up. but by two books, it's face is supposed to be even with the crank hub. and since it isn't by the book, it makes me say 'hmmm' when i see the wear rub on the original thrust plate
If you change the thickness of the thrust plate, aren't you going to mess up the end play on the camshaft? I seem to remember there's a stepped-down area on the cam gear that prevents the gear from being pressed too far onto the cam and locking up the thrust plate. I could be mistaken, however. Ive been working with a Ford 302 V-8 lately, and a couple of stovebolts, and they've both got cam thrust plates. I know for sure the thrust plate on the Ford also sets the timing chain alignment and camshaft end play.
The spacer ring (usually sold as a spacer ring/thrust plate set to control clearance) is chamfered on the I.D. on one side only and if installed upside down will not shoulder up against the journal properly.
You Tube
yeah, i thought about end play change, but since that's controlled by the spacer ring as curt said, it'd remain the same. the books show this checking being done before the cam gear is on the cam
