| | | Forums66 Topics128,113 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 17 New Guy | | New Guy Joined: Jun 2007 Posts: 17 | I have a 64 c10 in-cab tank and I can't get the sender gasket to seal for long.
First I tried Aviation Form-a-Gasket Sealant - lasted ~1 month then started seeping.
Second I tried Permatex #1 - lasted ~6 months and now it's seeping again.
I'm using the rubber gasket that came with the new sender. Is there some other gasket material that'll work better? Is there a better gasket sealer?
Tanks! Terry | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | There is a product called Seal-All.That is for gas.That would do it. It's odd however,my 52 uses a rubber gasket,and I didn't use sealant.No leaks.Humm Now you have me worried  | | | | | Joined: Jun 2007 Posts: 17 New Guy | | New Guy Joined: Jun 2007 Posts: 17 | Thanks! I'll try that. Maybe I should've not used any sealant in the first place. | | | | | Joined: Sep 2007 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 59 | I had similiar problems in my 54. I used seal-all and it has held for the past year. Also make sure your gas cap is venting. When your gas tank gets warm it builds up pressure and the pressure finds the weakest link. Which sounds like your gasket. Good luck. Hope this helps.
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Permatex Super 300 is a brush-on sealer that was developed to resist aviation gasoline. It's NOT the same stuff as the 3D brush-on liquid- - - -Super 300 is almost black while 3D is brown. A thin layer of Super 300, and a cork gasket if you can find or make one, should solve your problem. Most parts stores have sheet cork gasket material, and you can use your rubber gasket as a template to cut a cork one out. Jerry
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I had the same problem in my '50. I had bought a new gascap. It was vented, but required a few pounds of pressure to vent. I drilled a hole in the vent. Now its fine!
