4 members (ndkid275, Jeff Ogden, dt235sd, Bwana-Jim), 113 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
I don't have a set of running boards for my '46 1/2 ton. Since I'm going to put a wooden flatbed on it anyway I don't need the rear part of the running board that mates to the rear fender curve. Heavy-duty truck running boards end flat at the back already because they were all flat bed trucks anyway.
Will a large truck running board fit my '46 front fenders and running board mounts?
If it's from the same body style year, it should. You will have to knock off the rear board bracket as it will be of no use.
Bruce
My Trucks
Stuff I Collect
Yes it will fit no problem, they are cheaper too.
Brian D
My take is no. The larger trucks 1-ton up have a higher horizontal piece below the rocker panel. It was made this way as to compensate the step up to the running board due to the larger wheels and height of the cab. I do know that the 1/2 and 3/4 ton are the same. Perhaps you can find a set for the smaller truck that are in good shape from the aft of the cab fwd, and cut the remaining off?
Dale
9
9 Offline
with a cut off wheel and some patience they can be cut down to fit
if you have no options-- a lot of work but desparate times---
