1 members (Jon G), 136 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
I just purchased a Set of Fenton Headers for my 3100 Pickup project. I have now decided to get a two Single barrel Fenton intake for it. The original Rochester Carb worked good ,so I was thinking to buy another just like it. However , I am after input, if there is a better choice for Carbs.
Thanks for your help
JB
i have fentons on my 54 with two rochesters and work fine for me. around town with 2.7. rear end i only get 12-13 mpg but on a trip to Kansas city, 1400 miles round trip, i averaged 20.5 and a high of 23.5. BTW i have a t-5 overdrive trans.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
The Rochesters are easy to work on, easy to get and can be had reasonably, That is the way I would go.
Brian D
This is an interesting subject. How does the performance gain compare with (if any) increase of fuel consumption. I have dual exhausts with Fentons, and the stock intake with a Rochester carb. I am very satisfied with the way the truck runs. Acceleration is excellent. Would a dual carb set-up really add that much benefit, or is the main attraction the fact that it just looks so neat?
I have heard that you might get a 10% increase in Fuel Milage and horse power,[fenton Adv. I believe} however to be honest I wanted to do it because I think it looks good.
thanks for the input, I will stay with the Rochester carbs.
John B.
I have used original single-barrel Rochesters (matched 261 carbs) on a 261 engine and it ran as well or better than the dual two-barrel Carter-Weber carburetors I am now running.
The only way to really know what set-up is more fuel efficient is to run a test.
The only way to know what extra power might result from two carbs is to measure the hp.
I think that I have noticeably more power with two carbs. I have as good or better fuel economy with two carbs. I think that two carbs looks good (and, I think that two original Rochesters with original air cleaners looks the most interesting).
Tim
I like the original air cleaner idea. I will be looking for another of those.
JB
