9 members (chevy51truck, Gdads51, Woodcmiami, KEVINSKI, Peggy M, Wickedbass, Tinker5, Hotrod Lincoln, 1 invisible), 101 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#591619 11/11/2009 3:32 PM
Hi I am new to this site so I hope I am in the right Place.I am putting together what Ithink is a 1934 small 1/2 ton Chevy I want to keep the straight axle in it and build it as a nice mild street rod. It has been sitting in my brothers barn all apart for the last 35 years.The steel is like new. right know my biggest problem, it has no front axle, front springs or hangers on the frame I need to know what years fit this frame, also I would like to put Hyd. brakes on it. Can a later year axle be used? Can the spindles be changed on a 34 axle for Hyd. ? Thanks Fred
whatapain #591669 11/11/2009 7:55 PM
The following information might help answer your question about what year might fit your frame:
Here is a model identification chart.
You'll need that model ID but ignore the section number below (the correct section number is given in a post further down by waldo53.
5.420 is the section for front axles.
Tim
tclederman #591682 11/11/2009 8:20 PM
I would bet a lot of axle will fit, my '37 has a '55 axle under it, bolted right in. I never knew it till i ordered brakes and ling pins, neither fit since I ordered '37 parts.
Joe
Joe H #591735 11/11/2009 11:09 PM
Front axle part no.s begin at section 6.008 but unfortunately the master parts book doesn't give dims. There looks to be around 20 different axles listed.
This would make a great project for someone - an axle interchange chart!!
Sid, at droppedaxles.com might be able to shed some light on this.
waldo53 #593074 11/17/2009 12:07 AM
I
I Offline
I have a stock '34 axle (car) that had '37 juice brakes adapted to it. I believe it required the spindles as well as the hubs and drums. I think a simple spacer was needed to adapt the spindles at the kingpin. I have since removed the Huck brakes and drums and replaced them with finned Buicks.
Last edited by cletis; 11/17/2009 2:55 AM. Reason: removed reference to parts for sale.
