0 members (),
83
Mod | | | Forums66 Topics128,081 Posts1,056,318 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 16 New Guy | | New Guy Joined: Sep 2009 Posts: 16 | I'm going from the stock intake ('54 235) to a fenton dual intake setup with carter carbs. As far as installation, what am I looking at? New gaskets? Anything else? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Gasket(s),fuel line between carbs,throttle linkage and adjustment to the accelerator pedal rod and balancing of carbs. There is info in the Links and through the search system
Drew
| | | | | Joined: Sep 2009 Posts: 45 New Guy | | New Guy Joined: Sep 2009 Posts: 45 | What about the exhaust? If it's performance you're after, changing to a dual exhaust set-up (if you don't have it already) will benefit greatly. Our engines can be regarded as big air pumps, and anything that you do to eliminate airflow constrictions tweaks their power. It's a rather simplistic viewpoint, but it has worked well for me. Good luck! | | |
