5 members (JW51, Otto Skorzeny, Donf, Bill Hanlon, 1 invisible), 68 guests, and 2 robots.
Topics128,084
Posts1,056,334
Members48,442
I'm going from the stock intake ('54 235) to a fenton dual intake setup with carter carbs. As far as installation, what am I looking at? New gaskets? Anything else?
Gasket(s),fuel line between carbs,throttle linkage and adjustment to the accelerator pedal rod and balancing of carbs. There is info in the Links and through the search system
Drew
What about the exhaust? If it's performance you're after, changing to a dual exhaust set-up (if you don't have it already) will benefit greatly. Our engines can be regarded as big air pumps, and anything that you do to eliminate airflow constrictions tweaks their power. It's a rather simplistic viewpoint, but it has worked well for me. Good luck!
