7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Were there hub caps for the 18 inch wheeled 1 tons, factory or after-market? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | There were no factory hub caps but its difficult to say there no after-market caps. I do know I've never seen any.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | There were caps for the standard wheel but not the dually wheel. Saying this I don't know if they were an option or not. I have no idea about aftermarket caps but would assume somebody did make them. My parts truck came with two 18" Chevrolet 1 Ton hubcaps.
Bruce | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Speaking of this, does anybody know of a good source for caps for the 17" wheeels? I haven't gone through a search process yet, just curious.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | The bigger caps are really tough to find. When you do locate one or more, you might want to pick them up as you find them until you have a set.
Bruce | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | So, is the answer, mo, hub caps were not made, neither factory, nor aftermarket for the dual 18 inch wheeled one toms? I already knew that they were available for the single wheeled one tons, The Filling Station has repros. Thanks, Chris | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Correct to the best of my knowledge which is limited...you can ask my wife!
Bruce | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Bruce,
I was afraid you were going to say that.
Thanks, I'll keep my eyes open.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Jim Carter makes Stainless Steel reproduction hubcaps for 1946-1953 1-ton trucks Brian | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | I have one for a 54 and a couple for 47-53. This isnt the "for sale" section,though. I'll run an ad in the Swap Meet. | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | And my 2 sense worth..You might find some domed smooth chrome caps at yer friendly local truckstop...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Jim Carter makes Stainless Steel reproduction hubcaps for 1946-1953 1-ton trucks Brian I like this option, I've seen them first hand and they look very nice, and I remember thinking reasonably priced, but don't remember the price now.. Grigg | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i have a factory ad sheet that came with my 40 with all the new improvements added to the 250 series for 40. all the picures show hub caps front and rear for single and dual wheels. the front cap is held to the hub by a screw in the middle of the front cap. the caps for the rear appear to bolt to the hub itself or it screwed in the hole for pulling the axle out. i saw a pic of a 250 with front caps but the angle of the shot didnt show the rear. | | | | | Joined: Jan 2010 Posts: 38 New Guy | | New Guy Joined: Jan 2010 Posts: 38 | Chevs of the 40s has the Hub Caps for the 17" wheels. I think there $250.00 for a set of 4.
If it's broke hit it harder!
