0 members (), 151 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#59139 04/12/2006 9:49 PM
Junior Member
Junior Member
Ok so I am going to ask a silly question, on a 1958 to 1962 chevy 235 six , what type of oil filter system was used if any ? External or remote
or none.Thanks for answereing a silly ouestion for me. Chris
#59140 04/12/2006 10:27 PM
What is the difference between external and remote?
All 1958-65 235s that had an accessory/optional oil filter had an external, remote, by-pass (non-full-flow) canister oil filter (by AC, Fram, or others). The engine could have been later adapted for a full-flow oil filter (external and/or remote)
This is not a silly question. It is possible, however, that a majority of light trucks sold between 58-62 (with 6-cylinder engines) did not have an oil filter installed when purchased.
#59141 04/12/2006 11:37 PM
Junior Member
Junior Member
Ok so I am not loosing my mind, because I can not find eather or, in other words you just drove it for a bit and changed the oil, interesting.I am kinda new to the six cyl engine game,I have a 51 chevy wagon that has a 58-62 235 six and i was realy looking all around for the filter or external canister and could not find one so I thought maybe some one just took it off or when they did the engine switch forgot to install it.
Thanks for the info. Chris
#59142 04/13/2006 4:28 AM
Oil filters were an option! Easy enough to set one up now though- There are probably plugs in the block where the lines go.
