| | | Forums66 Topics128,204 Posts1,057,288 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | I keep seeing a 1960 shortbed truck an my way to work, and was wondering if I could swap out the body with my 1949 Chevy truck. What do you think? | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | I'm going to go ahead and say no, because the wheelbases of the two generations are probable different and the width of the frames may be an issue. I'm not 100% sure on these and I know someone will be along shortly to give a definative answer. You could look up the wheelbase specs for the respective years.
58' 3200 235 3-speed/OD
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Anything can be done with these old trucks. I think what you really mean to ask is, "is it easy?". And the answer is, maybe, but probably not. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Frame swaps are a lot of work under the best of circumstances. A '60 would get you a limited run front suspension that is hard to get parts for, in addition to being too wide in front.
I would say anything is possible, but this is a case where its not a good idea.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
