4 members (WICruiser, JW51, 1955 1 Series, Jay R), 151 guests, and 2 robots.
Topics128,083
Posts1,056,080
Members48,434
Where is a good spot to mount the coolant temp sensor on a 250ci. The temp gauge already takes a spot. It should be mounted "before" the thermostat.
I think i remember reading about an "adapter" that mounts between the thermostat housing and the block, which is used as a take off for water to warm the intake; it seems it would be a good place for a coolant sensor...
Is someone actually selling this or is this a home-made thing? If home-made, any advice on making one?
'57 Chevy Suburban; '70 Chevy Impala.
Riding in the Passing Lane
All of that era of 6 cyl. engines have a housing between the head & therm housing. It has 1 or more pipe thread outlets one of which is used for the heater outlet. If there is another opening with a plug in it this can be used for a senser. Most of them had an outlet on top the cyl. head about 1/3way back. Some had a outlet on top the therm housing, but that would not be very suitable for some sensors. If you don't have more then 1 on the intermitiat houseing you might find one from a later engine. When they started putting the emission controls on them they put outlets for coolant sensors.
1972 Chevy c10 Cheyenne Super
My 250 (from a '74 Nova) has the original "idiot light" switch under the thermostat. When I mounted the gauge, I put the sender in the left side of the head.
The truck, '65 C10, has green & red lights on the dash, presumably for cold & hot, respectively. I've never seen the green light come on. I might have the wrong temp. switch?
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
I drilled and tapped a hole in the thermostat housing. Mine had the boss there but it wasn't drilled out. Most temp sensors are between #2 and #3 cylinders in the head. Joe
