1 members (Hotrod Lincoln),
55
Mod | | | Forums66 Topics128,090 Posts1,056,376 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Who sells these? I need the fronts and the early AD rears 47-53 (for the clutch housing.)  | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I have never seen them for a 47-53 unless it was for a later model L6 or V8 conversion. You might have to search someone like Chassis Engineering for something that might work.
Drew
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | We tried Urethane suspension bushings on our over the road trucks about 15 years ago. They lasted a couple of years and then started disintergrating. My son also used some on his 90 GMC pickup and had the same kind of luck. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I got my urethane transmission mounts from Classic Parts of America (Old Chevy Duty). Not a great fan of the urethane mounts but mine have been in for 10K and show no signs of going south. No Urethane front insert available from that vendor.
Dave | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | My interest in urethane mounts was the idea they might resist oil and grease better. But since they don't exist, who makes the best rubber mounts? The old mounts are toast. I would pay for the best if the quality is known... | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Check out Steel Rubber. They have the best rubber parts for all of your truck. Cost a little more but worth it. George | | |
