7 members (Nick in Manitou, 66flea, Cletus1950, Hotrod Lincoln, 2-Ton, Jay R, TooMany2count),
333
7
Mod | | | Forums66 Topics128,158 Posts1,057,025 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Hello, Has anyone ever seen an AD seat which has a back that swings forward? The one on my new old fire truck does. I'm still trying to determine if it is a Van Pelt truck, or if not, which company made it. http://home.comcast.net/~chriseye/ft.htmlChris | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have seen a few converted to do this. Classic Trucks or one of those magazines had a "How to" on it a while back. You may find it in a detailed search here as well I know it has been discussed before. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | From what I can see it looks like a 55.2 seat. The hinge point and stop look like a 55.2 seat. Does it look like the seat is factory mounted or home grown?
Some more pics would help. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | that's definitely a TF [55-59] seat, including the 'adjuster' handle - looks like it's been taken off the TF slider tracks
Bill | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | I am in the process of removing the seat. Some of the bolts are rusty, so I sprayed them with PB Blaster, and will try again tomorrow. When I have it apart, I'll take more photos. The seat mount on the floor of the cab has been modified in a few places as is evident in the photo below the handle. I assume that the seat was installed to provide access behind the seat where the cab has two large openings which led to ? ? ? Could these Task Force seats been availablr in 53? I have added more photos to my fire truck page and will continue to do so as the project continues. http://home.comcast.net/~chriseye/ft.htmlChris | | |
