6 members (greenie-reddy, GMCJammer51, 2-Ton, 3B, 55shaker, JW51), 94 guests, and 0 robots.
Topics128,154
Posts1,056,834
Members48,456
Hi...
Last weekend, I started my truck up (as I do every weekend) and was greeted by an overflowing carburetor.
I tore it down this morning, and the only thing that I can think of that would make the carb overflow like that would be a bad float.
Well, the float still does its thing, and there doesn't seem to be anything in it (i.e. gas) and the bowl was still full of gas (as I expected it would be).
So, my fellow bolters, allow me to ask of you:
What the heck?
What else would cause an overflow like that, and how do I fix it?
Brendan,
I agree w/ TooMany2count....check your needle valve. My '61 did something similar before I had my carb rebuilt. Good luck. -Will
"Remember Who You Are And What You Represent"
"Being responsible sometimes means [censored] people off"
- General Colin Powell
you can use toothpaste to lap the needle and seat on that old float. sometimes they just need a little help
Jim & Caroline
Okay.
Thanks guys.
While I've got the carb cracked open, I might as well get a rebuild kit. It probably needs it anyway.
Also, I'll probably install a fuel filter. Just because I don't want this to happen too often. grin
Thanks for all your help, everyone!
I got the old girl running again tonight.
I made sure that all of the passages were free of crap and I figured that while I had it apart, I may as well rebuild it.
I gotta say, she certainly runs better! (Starts quicker too!)
