Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#5897 07/26/2002 7:55 AM
Should I use a primer on my engine first before I put the engine paint on? What kind of primer is heat resistant that I can get? What type of engine paint have you guys used? Is the rattle-can type a good plan? I appreciate your help. smile
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#5898 07/26/2002 12:15 PM
I ordered a engine painting kit from Por-15. I included the degreaser, primer and engine paint. I was very pleased with the results. There is a link to my webpage with a couple of pictures of the result on the thread about "Show off your engines."
Mike Kelley
1966 Chevy C10 SWB - 250 L6/S10 T5
2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
#5899 07/26/2002 4:41 PM
Primers main role is to provide a slightly rough surface for the enamel to adhere to. Since your block is a rough casting, apply two coats (min) of the enamel. If you're painting the sheet metal covers, prime them.
Fred
52 3600
69 C-10
#5900 07/26/2002 5:24 PM
I have heard that too many layers of paint on an engine can contribute to overheating. I don't know it that is true or not, just passing the "info" along.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
