4 members (Ponchogl, Millenimech, Jman, Shaffer's1950), 146 guests, and 1 robot.
Topics128,102
Posts1,056,531
Members48,448
#589089 11/02/2009 9:07 PM
I just removed the rear leaf springs on my 66 k-10 and found a cracked rear most shakel mount on the left side. It is cast and I was told some people can weld them. Is this true or should I look for a new one? The two lower ears where the rivets went through are snapped off.
That shackle takes a real beating. I drove my '02 Ram 2500 with a broken shackle mount for weeks wondering what was making all that racket. I thought the new muffler & tailpipe were installed poorly and kept going back to the shop that put it on. When I finally crawled under there and looked the rear end of the leaf spring was riding on the bottom of the bed! I appologized to the muffler guy. The point is that it is not a critical failure but who wantsto risk it? I'd vote to replace it.
Dave.
What's the last thing a red neck says, "Hey guys watch this."
What's the last thing a redneck hears, "Go ahead Bubba, you can do it."
Build plan: 65 Chevy one ton, 5.9L Cummins HO, NV5600 six speed, 2wd 1972-1987 IFS disk front, frame off restore/mod, custom dump/flat bed, Alcoa rims, Dana 70 3.73:1 duals drum rear, plush interior, Guards red with Marine Corps decals. Donor is retired 2002 Ram 2500, 194K miles.
if you can get the spring hanger i would put it on ,other wise you have to do what you have to .i only had to have the pin hole,s bored out and sleaved on mine ,but A good welder can weld cast iron .
