| | | Forums66 Topics128,004 Posts1,055,265 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58917 04/09/2006 1:37 PM | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | Just installed a new metal speedometer cable on my 1941 1/2 ton. Man does it scream!!!! What causes this. It's coming from the back of the speedometer itself. I have checked all the connections and they are good and tight. Thanks for your help.
Greater love have no man than this, That he let his wife drive his truck to the grocery store. ........
#58918 04/09/2006 4:04 PM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Did you lube the cable? The core of the cable should slide completly out, I used white grease. | | |
#58919 04/09/2006 4:27 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | any grease/oil is a bad thing for speedo cables - use dry graphite only - with a new cable it'll be a dirty old speedo screamin, not the cable
Bill | | |
#58920 04/09/2006 6:23 PM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Well, I was only reading the label....I have a tube of "Lubriplate" (white grease), and it says right on the label that it's for speedometer cables. :confused: . Me personally, I would still lube the cable. I can see a speedometer make a rub or ticking sound, but not a "screaming" sound. | | |
#58921 04/09/2006 6:56 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check a brand new cable and see what it's "lubed" with - the high speed the cable insert turns heats oils and attracts dirt and grit to shorten useful life - gummy/sticky speedos can make sounds you'd only expect to hear from a stuck pig or a very unhappy baby Bill | | |
#58922 04/09/2006 11:28 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I have a "screaming" speedometer on my hotrod Packard. Is there anything I, not a shop, can do to fix it? Any web sites that offer any hints? Thanks
#58923 04/09/2006 11:34 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,ve put grease in them for 55 years & have not had a problem. Some times the core is a little to long & jams it. Try running with the collar a little loose. Spray a little WD40 type lube onthe stem of the speedo. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#58924 04/10/2006 3:21 PM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | My '41 is well lubed and makes no noise at all. At least I can't hear it over the transmission. How fast are you going?? | | |
#58925 04/10/2006 4:06 PM | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Did you try driving without the cable attached to the speedometer to see if it makes any noise? It may not be the cable that is making the noise.
Ed | | |
