Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Lostbuthaulinass, 78buckshot, baldeagle, TUTS 59, WICruiser, Otto Skorzeny), 43 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#58917 04/09/2006 1:37 PM
8
8 Offline
Just installed a new metal speedometer cable on my 1941 1/2 ton. Man does it scream!!!! What causes this. It's coming from the back of the speedometer itself. I have checked all the connections and they are good and tight. Thanks for your help.
Greater love have no man than this,
That he let his wife drive his truck to the grocery store.
#58918 04/09/2006 4:04 PM
Did you lube the cable? The core of the cable should slide completly out, I used white grease.
#58919 04/09/2006 4:27 PM
any grease/oil is a bad thing for speedo cables - use dry graphite only - with a new cable it'll be a dirty old speedo screamin, not the cable
#58920 04/09/2006 6:23 PM
Well, I was only reading the label....I have a tube of "Lubriplate" (white grease), and it says right on the label that it's for speedometer cables. :confused: . Me personally, I would still lube the cable. I can see a speedometer make a rub or ticking sound, but not a "screaming" sound.
#58921 04/09/2006 6:56 PM
check a brand new cable and see what it's "lubed" with - the high speed the cable insert turns heats oils and attracts dirt and grit to shorten useful life - gummy/sticky speedos can make sounds you'd only expect to hear from a stuck pig or a very unhappy baby grin
#58922 04/09/2006 11:28 PM
I have a "screaming" speedometer on my hotrod Packard. Is there anything I, not a shop, can do to fix it? Any web sites that offer any hints? Thanks
#58923 04/09/2006 11:34 PM
Riding in the Passing Lane
I,ve put grease in them for 55 years & have not had a problem. Some times the core is a little to long & jams it. Try running with the collar a little loose. Spray a little WD40 type lube onthe stem of the speedo.
1972 Chevy c10 Cheyenne Super
#58924 04/10/2006 3:21 PM
My '41 is well lubed and makes no noise at all. At least I can't hear it over the transmission. How fast are you going??
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#58925 04/10/2006 4:06 PM
Did you try driving without the cable attached to the speedometer to see if it makes any noise? It may not be the cable that is making the noise.
Ed
