3 members (Gdads51, Peggy M, Jon G), 118 guests, and 1 robot.
Topics128,126
Posts1,056,353
Members48,441
1958 apache 3200. I am re-doing the entire brake system. Lines, cables, etc. Top to bottom.
1 catch so far is I don't know how to remove the old e-brake cables from the truck.
I got them out of the brakes easy enough - how do you get them out of the frame?
Last edited by Woogeroo; 11/06/2009 2:09 AM. Reason: added year and model to title
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
looky here - the spring acts to keep the cable from rubbing the back of the tire, release it but don't lose it - the small bracket at the end of the outer housing the cable goes into has a clip [should] inside it, remove that clip and the cable will pull out after you undo it from the clevis where the 2 cables join the front cable
Sometimes on the end of the cable there is 3 small fingers...
Use a pipe or deep socket, even a box end wrench to collaspe the fingers to remove cable thru hole in frame...
GMC: Get More Cash...
1958 GMC
My Webshots photos
H Online: Content
I use a small screw-type hose clamp to collapse the spring fingers, then pull the housing assembly back through the hole in the backing plate.
I use the screw clamp too. Don't tighten it any more than just enough to get it started thru the backing plate. Its easier to feed thru the hole if you really crank it down but the fingers lose most of their spring if you do that (he reminds himself).
Chuck
Thanks guys - I already have the cable out of the backing plate.
I have not removed the spring yet & will take a closer look at where it goes through the frame.
Squeeze - as you look at your picture - follow the cable up until it enters the frame. That is the spot I need help with. How do I get the cable out of there?
The new cables will show up in the next couple of days. I'd like to have everything ready.
bone stock 235
53k miles
3 on the tree
H Online: Content
Look at the back side of the bracket- - - -away from the cable. Use a mirror and a bright light if necessary There should be a hairpin-shaped spring clip retaining it that can be removed with a little ingeneuity. Sometimes there's a flat spring retainer similar to the one that holds the frame end of a brake hose in place.
Originally Posted by squeeze
.... the small bracket at the end of the outer housing the cable goes into has a clip [should] inside it, remove that clip and the cable will pull out after you undo it from the clevis where the 2 cables join the front cable
My advice is don't throw the old ones away until you have the new ones installed and you are staisfied!
1951 1 Ton Completed
Truckernix - I'll take your advice.
bone stock 235
53k miles
3 on the tree
