3 members (Joe H, Gdads51, UtahYork), 99 guests, and 2 robots.
Topics128,264
Posts1,058,355
Members48,485
#588677 11/01/2009 2:00 PM
We tried to start the engine on my 52 after converting to 12v and the old 6v starter blew apart. I'd like to replace it with a new 12v starter but I didn't see 12v starters the Carter or LMC catalogs. Several strings suggest the 6v starters are fine for a 12v system. Should I just get a replacement 6v or is there a good place to go for 12v starter?
_________________________
rockhammer #588702 11/01/2009 3:31 PM
Riding in the Passing Lane
A 6 volt starter should work fine on 12 volts. The later model 12 volt starter will not work with the older flywheel/bell housing.
1972 Chevy c10 Cheyenne Super
Thnaks very much. Just curious..is your Fleetside color "Saddle Brown"?
-Phil
rockhammer #588792 11/01/2009 8:06 PM
It was that color when I got it. I don't know what they call it or were it came from. When I get through with the mechanics I will see about matching the paint & do some touch up.
When you say it blew up are you talking about the solder came out of the armature pins? Your typically ok using the 6 volt starter, however, like any starter 6 or 12 it will only take so much. If you cranked on it long enough the starter will heat up to the point of blowing the solder out of the armature pins. When this happens it usually takes the field coils with it. If your wanting to upgrade to 12 volt PM me and I can give more helpful info on this.
Ken
