1 members (qside),
157
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 38 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 38 | We tried to start the engine on my 52 after converting to 12v and the old 6v starter blew apart. I'd like to replace it with a new 12v starter but I didn't see 12v starters the Carter or LMC catalogs. Several strings suggest the 6v starters are fine for a 12v system. Should I just get a replacement 6v or is there a good place to go for 12v starter? Thanks _________________________ | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A 6 volt starter should work fine on 12 volts. The later model 12 volt starter will not work with the older flywheel/bell housing. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 38 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 38 | Thnaks very much. Just curious..is your Fleetside color "Saddle Brown"? Thanks, -Phil | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It was that color when I got it. I don't know what they call it or were it came from. When I get through with the mechanics I will see about matching the paint & do some touch up. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | When you say it blew up are you talking about the solder came out of the armature pins? Your typically ok using the 6 volt starter, however, like any starter 6 or 12 it will only take so much. If you cranked on it long enough the starter will heat up to the point of blowing the solder out of the armature pins. When this happens it usually takes the field coils with it. If your wanting to upgrade to 12 volt PM me and I can give more helpful info on this. Ken
