4 members (ShopRag, Phak1, Gdads51, Hotrod Lincoln), 88 guests, and 7 robots.
Topics128,181
Posts1,057,152
Members48,464
The other day I was driving a new project home that sounded great around town but once on the freeway, towards the end of the trip it developed a knock. Oil pressure showed on the gauge but wasn't overly high. I've also noticed a cough in the exhaust on the left bank at idle. I'm guessing maybe bearings and an oil pump?
This was a trade that is basically a freebee and it's a '67 Ford so I'd like to get it running well and trade it off for another GMC.
Mabe a stuck exhaust valve or a bent push rod or broken rocker You might want to check that frist .
Pete
Don't know if this could be related or not, but have you checked and adjusted the valves?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Well, now I see my hunch is Pete's too..
Let us know what you find,
Grigg
I'll take a look tomorrow and let you know.
Riding in the Passing Lane
I'm wondering if a piece of carbon broke loose & was sitting on top the piston & then part of it got into the exhaust valve.
1972 Chevy c10 Cheyenne Super
If its a 302, change the plugs. When a plug goes bad on a 302, it sounds like a rod is out. Dont know why, just know it is.
Originally Posted by GreenGMC
...it's a '67 Ford ...
Originally Posted by Scott Danforth
If its a 302,..
Are we still on the same page?
I know both GMC and ford offered a 302, which one are we talking about?
It's a 352
I pulled the valve covers today and it has hydraulic lifters with no valve adjustment at all??? Adjustment determined by push rod length only? No broken lifters. I did notice that the valve covers and heads are extremely gunked up which makes me wonder if a lifter is gummed up. I might get a can of engine flush later today as see cleaning it out makes a difference on the cough and the oil pressure issue.
