7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible), 125 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#588369 10/31/2009 5:23 PM
I have a 1968 chevy longbox that I would like to put on a 1991 chevy long box frame. I know that I would have to take 5 inches out of the 91 frame as the 68 has a 127 inch wheelbase, and the 91 is 132 inches.
Has anyone done a conversion like this before?
Just out of curiosity, why are you wanting to swap frames? Not much, if anything, to be gained by swapping. The '68s already have IFS, and upgrades are very easy to do.
Bill Burmeister
I guess because the upgrades that are already on the 91 would cost me thousands of dollars to put on the 68. Disc brakes, Handling equiptment, etc. This whole thing is just a thought as the 68 frame is fine.
TC, if I remember, there are tubular A-arms for your 68 that are not too bad. A set of Q1 coil overs and a 4-bar setup would be low$ as well. While you are right, it will set you back about $1000 to $1500, it would be better than a stock '91 unless you did the same upgrades.
Disc brakes were available in '71 if I remember right. So you may have parts available.
Yes, '71 was the first year for the disk brakes, and with some parts swapping, spindles from the '73-'87 can be installed to the original control arms. Out back, the stock '68 suspension will outperform the leaf spring rear handling wise, or as Scott pointed out, a 4 bar can be easily installed.
For the time, effort, and cost to swap the frame, you would be ahead to upgrade the stock frame, and get a better handling and braking truck, plus you'll have a truck that the frame and body align to each other correctly.
Bill Burmeister
