| | | Forums66 Topics128,088 Posts1,056,113 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 40 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 40 | I have a 1968 chevy longbox that I would like to put on a 1991 chevy long box frame. I know that I would have to take 5 inches out of the 91 frame as the 68 has a 127 inch wheelbase, and the 91 is 132 inches. Has anyone done a conversion like this before? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just out of curiosity, why are you wanting to swap frames? Not much, if anything, to be gained by swapping. The '68s already have IFS, and upgrades are very easy to do.
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 40 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 40 | I guess because the upgrades that are already on the 91 would cost me thousands of dollars to put on the 68. Disc brakes, Handling equiptment, etc. This whole thing is just a thought as the 68 frame is fine. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | TC, if I remember, there are tubular A-arms for your 68 that are not too bad. A set of Q1 coil overs and a 4-bar setup would be low$ as well. While you are right, it will set you back about $1000 to $1500, it would be better than a stock '91 unless you did the same upgrades.
Disc brakes were available in '71 if I remember right. So you may have parts available.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, '71 was the first year for the disk brakes, and with some parts swapping, spindles from the '73-'87 can be installed to the original control arms. Out back, the stock '68 suspension will outperform the leaf spring rear handling wise, or as Scott pointed out, a 4 bar can be easily installed. For the time, effort, and cost to swap the frame, you would be ahead to upgrade the stock frame, and get a better handling and braking truck, plus you'll have a truck that the frame and body align to each other correctly.
