0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | Does a sway bar on the front end make a difference? I have a '51 GMC 1/2 ton. | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Good question. My '52 Chev is so darned stiff I never considered it, plus like to keep it original. Like to see what others say.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Thomas & Scott: I asked that question for my 59 and the answer I liked do you want to stop the roll in the corners. Shortly after that (I'll see if I can find the article Classic Truck) talked about improving your old truck ride w/sway bars. Convinced me!! Right after Christmas I am ordering a set for front and rear. Now remember I am staying with stock suspension, and this is a big improvement. Ben
popcorn The Truth is Out There (Hope this helped) | | | | | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Makes a huge difference on cornerin ability and it seems to me that the difference is greater on 53 and earlier trucks (although I can't point to any reason why) Those earlier AD trucks just seem more tippy.
Buzz'n Half Dozen
#5876 12/06/2004 10:28 PM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | If you can find one, Chevy offered a front sway bar for their panel trucks, not sure about on the regular trucks. But same axle is used on both. Make sure you get all the hardware from the donor vehicle. | | | | | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | I saw no perceptable improvement with the panel truck sway bar.
Jason
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | thomas, brotherstruck.com, chevyduty, harmons.com and other of the aftermarket sites offer sway bars complete with no or little work on your part to install. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Oct 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 66 | It worked very well on my '50 1/2 ton. Maybe the lighter the truck the better they work? | | | | | Joined: Jan 2003 Posts: 35 Junior Member | | Junior Member Joined: Jan 2003 Posts: 35 | 3100 since you are happy with the result of your sway bar addition, the next logical question is where did you get them?
duddy | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I added a front sway bar on my 51 years ago, it came from Patrick's,I think it's stiffer than the original Burb type.The improvement in normal handling is very noticable,no more feeling that the back end wants to get away in turns. | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | The original panel truck sway bar is about as big around as your pinky. The aftermarket sway bars are about 3x as big. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Don't buy a chev sway bar and think it will fit a GMC. GMC uses a special mount because the crossmember is at an angle where the sway bar mounts.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 66 | Duddy, I purchased mine from Chevy Duty. The box was missing the instruction sheet, but CD faxed me one after a few emails, and a telephone call.
It went in fast, and works great! | | |
#5885 12/19/2004 12:44 AM | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | I purchased a front kit for my 57, but found the instructions difficult to follow. There was a bold disclaimer that the kit was intended only as an OEM replacement, but upon examination of a TF panel truck, found it not even close to OEM design. The pencil diagrams were atrocious so I decided that, for something as important as front end control, I would abandon the project. The June 04 issue of Custom Classic Trucks has an article on TF sway bars. The photos of the kit look just like mine, and the installation photos are very clear. After Christmas tree season, I'll bring the old beast into the garage and try the installation again. | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | I have a original sway bar and mounts from a 1950 1/2ton panel, if anybody wants one. | | |
