4 members (Tiny, Otto Skorzeny, 2 invisible), 111 guests, and 3 robots.
Topics128,142
Posts1,056,476
Members48,441
#587380 10/28/2009 4:43 PM
Anybody know a NAPA part # for the front pinion seal on my 59 1 ton GMC Napco?
Is it the same as a 3/4 ton? I can get that for you tomorrow if you still need it.
1956 Chevy 3600 NAPCO 4x4
1955 Second Series Chevy Short Box
1956 Chevy 3100 Short Box
Story in the Gallery
More pix and info on my web site
Don't know if this is the same - SKF (www.skf.com) seal part #25970. Not NAPA, must have bought this from one of the others...
It's on my '56 3600.
if you take the old one out it will have manuf # on it. Napco may have it's own part #, but theere will be a manuf # and it will more than likely be a common seal avail at most automotive jobbers or bearing shops
ron
you will also more than likely require a "speedi-sleeve" to repair the wear in the pinion shaft where the seal ran on it
bet these guys know
http://www.napco4x4.org/
rednate's suggestion is a good one. I am not a 100% sure, but I seem to recall that they started a reference list for bearing and seals for the NAPCO parts there. Also, if you go to eBay and search for chev* napco, there is an vendor that regularly sells there (ddautoparts, I think), I have talked to them and they are very nice. I'm sure they wouldn't mind answering your question if nothing else pans out.
