| | | Forums66 Topics128,006 Posts1,055,272 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | I just got the shiftbox back from Jim Carters, and installed it today. Seems as if I have something out of alignment, because 2nd and 3rd are easy to get, but 1st and reverse are hard to find. It just seems like I can't pull the shifter back towards me to find 1st. I did some adjusting on the rods from the trans, up and down, but only helped with 2nd and 3rd alittle. Does anyone have any other things to try? Thanks. | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | No one has any ideas for me? I can't imagine that I am the only one that has ever had this problem. Of course, that is my luck with the things on this truck though. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You should adjust the rods so that you can pull forward & back in neutral without without catching. You may have it mounted too close or too far back from the shift lever. There is a little room for adjustment in the coupler that mounts the shafts together. It's all a matter of getting the correct adjustments. Carters has a good tech. adviser if you can't get it right. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | Hey thanks George, I am going to try and move it a little and see if I can get it. If not I will definetly give Carters a call. Thanks again. | | |
