3 members (Otto Skorzeny, klhansen, Bwana-Jim), 75 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#586796 10/26/2009 10:06 PM
Has anyone used the do-it-yourself windshield repair kits that you can get at the FLAPS? I had a rock jump up into the windshield the other day. The chip isn't in my line of sight, so I'm just trying to make sure that it doesn't turn into a crack, and make it a little less visible.
Bryan
1954 3104 235 "AD" L-6 3-on-the tree
Bryan...I've not used the DIY version,but I do use a repair kit in my work.
If you can, gently heat the windshield from the inside while applying the pressure from the injector. This will help the resin flow a bit better.
Also try and do it in shade as the resin cures with UV light. this will give you more working time.
I also apply pressure to flex the damage from the inside but it's a risk as too much can make the chip/crack worse!
Let us know how it turns out.
Jock
More pix on Flickr.
Ex Hall Monitor
Ex Hall Monitor
If you have comprehensive coverage on your truck all insurance companies I've dealt with will wave the deductible and pay to fix the chip professionally. I haven't used a do-it-yourself kit so I can't help you there.
Tiny #587005 10/27/2009 2:49 PM
I did many years ago and I wasn't impressed.
Tiny #587156 10/27/2009 11:59 PM
Good point Tiny, plus it keeps me in employment! thumbs_up
Now why didn't I think of that!
More pix on Flickr.
I contacted my state farm agent, and they said that they can give a discount on having it done, but it isn't covered by my plan...
It would be $50 to have it done by safelite, and the kits at the store are about $10....so I'm not sure what I'm going to do....
the chip is tiny... about the size of a pencil eraser.
Bryan
Ex Hall Monitor
Ex Hall Monitor
That means you don't have comprehensive coverage. A small chip can turn into a large crack and a repair (replacing the glass) costing far more than $50.
Tiny #587472 10/28/2009 10:28 PM
If you're gonna try the kit, read the instructions. Tiny's setup may use pressure, but the kits use vacuum.... You pull up on the plunger and hold it until the air in the chip bubbles through the fluid, then let it go so it snaps down, pushing the fluid into the chip. Do this four or five times to get all the air out. Less air=better repair.
Good luck.
You should call around to the local glass guys. Peoria has a place that will fix these for $10 w/o insurance. You just drive in plop down your cash & drive away when they are done.
There has to be a discount place around you.
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
