1 members (tesa),
142
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | king pin lock pin -1950 1/2-ton - how in the heck does that thing come out?! loosened the nut, jb spray, but i'm bending the pin/ruining the threads even though i'm hitting the nut. torch rust expansion?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A hydraulic press would be the best way. A little heat shouldn't hurt it. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had to drill mine out. It was a very scary process as my skills in that kind of a process are limited. In the end I didn't affect the bore walls at all and it ended on a happy note! | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Heat it up with a torch or even a propane torch if You have one and take Your time heat it up good and hot than give it a good hit with a hammer if that does not work than You may have to grind the thread side down so it's flush and drill it out just start out with a small bit and move up a little at a time when You get close to the size I take and try heating up again and use a punch with a flat tip to try hitting it out again after drilling most bolts come out just take Your time she's been in there a LONG time .
Pete | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If you beat on it you probably swelled it up. When that happens, I grind the bolt off so it is flush with the beam eye, apply some head and hit it with a punch about the same size threads were. I have also had luck with an air chisel with a flat punch bit. Between the heat and the rattling of the air chisel I have always managed to get the pins out. | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | thanks - i'll be back at it in the morning. i had a similar problem with the rear shackle pin but it popped loose after a few taps | | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | I had to drill mine out. It was a very scary process as my skills in that kind of a process are limited. In the end I didn't affect the bore walls at all and it ended on a happy note! Yep thats what i did. Drilled until there was only about a 16th of a inch left then used a punch. Be careful when re-installing them as one side of the axle's hole is bigger than the other | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | well, i got it out with a little heat and beat. i was even able to salvage the threads with a die. but now, how do you get the king pin out? i removed the caps, one was very hard to remove/ drill/dig etc, and i beat a socket to death and have nothing to show but a beat socket. mind you, the spindle/knuckle does not move. more heat and beat? | | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Kingpins can take a lot of force to get out. The best method is to remove the axle and use a press. If you pound them out with a sledge, you can deform them and cause damage to the hole in the axle. Ask me how I know! | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | i forgot to mention; i'd take it in the house and press it out, but recent surgery says no. so, i'll wedge the axel between two trees and use a lot of jb and that 4' pipesuasion
and....i got all my motor stuff back, in the house, and the block's on the stand. but i can't take a chance by lifting the crank and go'in ta town | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | well, i did manage to get the axel to the press, and still no luck. am i missing something? in one diagram, they show a snap ring, but there's none in mine
urrrrgggghh! | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Alot of heat , even than they can act like they are glued in , I had to change king pins in My 79 3/4 ton Ford van one side came out like butter the outher side would not move I took it to freinds shop and He had a screw press that We put on the axel and than heated it up and with the help of a 3/4 impact tool and a good smack with a BIG hammer got it to move try putting pressure on it and heating it up HOT with the pressure on it if You could give it a smack she might give it up .
Pete | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | finally! we pressed it out at the shop. and i see why my little 10ton mini-press didn't work - it took 12-15ton to get them to break loose. i sure wouldn't want to have to try to get them out while still on the vehicle | | |
