5 members (Gray_Ghost, frogfarmer, Otto Skorzeny, jay d, 50Chevy3100), 52 guests, and 3 robots.
Topics128,056
Posts1,055,804
#586194 10/24/2009 9:55 PM
king pin lock pin -1950 1/2-ton - how in the heck does that thing come out?! loosened the nut, jb spray, but i'm bending the pin/ruining the threads even though i'm hitting the nut. torch rust expansion?
A hydraulic press would be the best way. A little heat shouldn't hurt it.
Cletis #586279 10/25/2009 3:28 AM
I had to drill mine out. It was a very scary process as my skills in that kind of a process are limited. In the end I didn't affect the bore walls at all and it ended on a happy note!
1951 1 Ton Completed
Heat it up with a torch or even a propane torch if You have one and take Your time heat it up good and hot than give it a good hit with a hammer if that does not work than You may have to grind the thread side down so it's flush and drill it out just start out with a small bit and move up a little at a time when You get close to the size I take and try heating up again and use a punch with a flat tip to try hitting it out again after drilling most bolts come out just take Your time she's been in there a LONG time .
Pete
If you beat on it you probably swelled it up. When that happens, I grind the bolt off so it is flush with the beam eye, apply some head and hit it with a punch about the same size threads were. I have also had luck with an air chisel with a flat punch bit. Between the heat and the rattling of the air chisel I have always managed to get the pins out.
thanks - i'll be back at it in the morning. i had a similar problem with the rear shackle pin but it popped loose after a few taps
Yep thats what i did. Drilled until there was only about a 16th of a inch left then used a punch.
Be careful when re-installing them as one side of the axle's hole is bigger than the other
cshamel #586830 10/27/2009 12:18 AM
well, i got it out with a little heat and beat. i was even able to salvage the threads with a die. but now, how do you get the king pin out? i removed the caps, one was very hard to remove/ drill/dig etc, and i beat a socket to death and have nothing to show but a beat socket. mind you, the spindle/knuckle does not move. more heat and beat?
Kingpins can take a lot of force to get out. The best method is to remove the axle and use a press. If you pound them out with a sledge, you can deform them and cause damage to the hole in the axle. Ask me how I know!
i forgot to mention; i'd take it in the house and press it out, but recent surgery says no. so, i'll wedge the axel between two trees and use a lot of jb and that 4' pipesuasion
and....i got all my motor stuff back, in the house, and the block's on the stand. but i can't take a chance by lifting the crank and go'in ta town
well, i did manage to get the axel to the press, and still no luck. am i missing something? in one diagram, they show a snap ring, but there's none in mine
urrrrgggghh!
rednate #587128 10/27/2009 10:00 PM
Alot of heat , even than they can act like they are glued in , I had to change king pins in My 79 3/4 ton Ford van one side came out like butter the outher side would not move I took it to freinds shop and He had a screw press that We put on the axel and than heated it up and with the help of a 3/4 impact tool and a good smack with a BIG hammer got it to move try putting pressure on it and heating it up HOT with the pressure on it if You could give it a smack she might give it up .
Pete
Pete52 #587502 10/28/2009 11:54 PM
finally! we pressed it out at the shop. and i see why my little 10ton mini-press didn't work - it took 12-15ton to get them to break loose. i sure wouldn't want to have to try to get them out while still on the vehicle
