| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 45 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 45 | I'm rebuilding my '55 12V Delco generator and when I oiled the rear bushing the oil just ran out so I removed the round metal cover on the cavity below the rear bushing and there's nothing in there! Is there supposed to be something in there and, if so, what does it look like? I've searched the forums but didn't find anything on this particular subject.
Finally '54
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | They look like THIS..........Joe | | | | | Joined: Oct 2007 Posts: 45 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 45 | Thanks; I have the bushing. It's the "oil cavity" below it that's empty. Is there supposed to be felt or something in there to soak up the oil for the rear bushing? Or are the replacement bushings oil-impregnated bronze that require no lubrication?
Finally '54
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The bushing is oilite bronze, which really doesn't need lube, but if you want to go traditional, put a piece of cotton sash cord into the opening under the oil cup and drip just a little SAE 30 oil into it. The oldtime generator rebuilding kits included new oil wicks, along with bushings and other small parts necessary to do a good rebuilding job. Jerry
| | | | | Joined: Oct 2007 Posts: 45 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 45 | Great! Thanks for your help. These forums are awesome!
Finally '54
