6 members (Otto Skorzeny, Gdads51, 3B, 55shaker, Woodcmiami, 1 invisible), 262 guests, and 2 robots.
Topics128,086
Posts1,056,098
Members48,434
#586220 10/24/2009 11:53 PM
Apprentice
Apprentice
Has anyone lowered the stock seats in a 51? or when you switch out to bucket seats are you riding lower in the cab. I'm 6' 4", my son is over 6' 5" and my eyes are just about even with the top of the door window. I was wondering if there is a way for the seat springs to be modified, lowered. Does the gas tank have to be moved out of the cab for buckets seats to work. We do OK with leg room but a little more wouldn't hurt.
I am still using the stock seat in my '49 but I cut out the riser where it is connected to the floor , sliced off 1" and tack welded it back in . I think it sets better this way = makes it a little easier to see the stop lights !
Apprentice
Apprentice
Very interesting solution, I'm going to look into that. Did you just take off an inch cause that was all you wanted or do you think that would be maximum that could be removed.
Thanks, Martin
I just removed one inch because I wasn't sure if I would get results that I needed , I needed more headroom but couldn't afford to loose legroom . I am ok with how it sets like this so I didn't want to go a little more and end up removing too much to still be somewhat comfortable.
Jim & Caroline
We've got an 88 full size Chevy truck seat in our '54 and at 6'1" it was too low so I made 4" risers out of flat stock bent into an "S" on each side. The seat was free. If you are that much taller, you can easily change the height by not making the uprights on the "S" form as long.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
Moderated by  ndkid275, Phak1
