0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | Well I have had this truck some time now and close to driving it daily eventhough planning other changes in the future.I purchased this as a 46 1.5ton but my vin plate is almost impossible to read. Faintly it shows load master, at the bottom center is stamped "90S04" bottom right 9159, nothing else is visable. vin buster didnt work and also tried the rest of our options on this forum and lots of web sites with vin id failed. Any other info will help?  | | | | | Joined: Dec 2007 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 43 | CAJUN draw fish I had similar problems with my serial number, ( thinking it was vin buster) But I was wrong, my serial number and title had an O in place of an “Q” So, I tried your serial number with a “Q” (wrong result below), then I tried a Capital O, and got the last results below… I’m betn that’s your truck, but check your wheel base .
Serial # : 9QS049159 (wrong) Mfg Year : 1947 Model : 2 ton COE Wheelbase : 158 inches Plant : Norwood, OH
Or
Serial # : 9OS049159 (my bet correct) Mfg Year : 1946 (interim) Model : 1.5 ton Wheelbase : 160 inches Plant : Norwood, OH
Regards, n hope this helps Loadmaster47
| | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | Why is the simple things turn into mountains and ya feel like an idiot? Dont answer, but thanks a lot, loadmaster47. Have a blessed night. | | | | | Joined: Dec 2007 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 43 | no big deal,,glad I could help loadmaster47 | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Cajun, Your title or bill of sale may have the # you are looking for. Have you checked this? Harold
Harold Is a restoration ever finished? | | | | | Joined: Dec 2007 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 43 | Harold46 & Cajun
My Mass. title had the "wrong" letter (O) not the (Q) on it Knowing how inconsistant / screwed up the Reg of Motor V (RMV) is, I made a decission to NOT fix either the title or the door post plate.... whay too much aggravation and added expense. I plan on keeping my truck for ever.... your mileage and experiance my vary...:>)
regards Loadmaster47 | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | I have a set of number and letter stamps. Changing an ID tag is lots easier than changing a title. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have a set of number and letter stamps. Where did you get stamps that look like the original numbers? A guy I talked to some months ago had looked all over creation and had not found the right ones anywhere.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | I actually bought them with a bunch of other stuff when the GMC house sold out back in the 60's. Back in those days the GMC house installed a lot of short blocks and stamped the rest of the numbers on the distributor boss because thats how the vehicles were titled in Texas in the early 50's. The wooden boxes don't say GMC, but they stamp narrower than the Chinese numbers you get now. I even have one more blank ID tag that came with the stuff. I bought a repop on eBay recently, but it is noticeably different than the real one. I think probably any numbering set that is 50 years old would look more like the original. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Sounds like you found the right solution but its not one easy for others...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2007 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 43 | I am prety sure in my state (mass), when you alter / tamper with the serial numbers / VINs, you are breaking the law. they ( VIN/ serial # ) can only be authorized or modified by the Registry of motor veh..
like I said in my last post... I'm just going to leave my original wrong numbers as is ( cuz they both match ) Your states may be different. I'd suggest that you investigate more before you alter the serial tags... loadmaster47 | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | It is probably a felony in every state. It certainly is in the State of Washington.
I watch these threads with some fascination in part because people are announcing publically that they intend to break the law.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | I am actually a licensed salvage dealer in Texas. They are very particular about late model stuff and everything has to be documented. They don't really about vintage stuff unless they have reason to believe that something is stolen. Everyone of my over the road trucks was reconstructed from salvage. I have documented where the components came from. Late model trucks have the vin stamped on the frame as well the door jamb. Quite often the cab and frame were not born together. Prosecution must prove fraudulent intent. This is a difficult task for the prosecution if there was no fraud involved. | | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | Call me chicken but up here in Michigan I wouldnt take the chance and there pretty strict. Thanks again loadmaster47, my problem was resolved in the first replies you gave.  | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | --side note to C.C.F.--
you can fix the photobucket link in your signature line by removing the space between the = and the http.
Go to:
My Stuff >> Edit Profile
At he bottom of the page, in the box where you type your signature in, place a cursor just before the http and backspace once, then click <SUBMIT>
It should work then. | | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | Thanks 54TOW I didnt notice there was a problem and we all want to show our bolts off, restored or not.
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | | | | | | Joined: Dec 2007 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 43 | whew !!... glad I could help, | | |
