0 members (),
146
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 75 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 75 | Hi, My 1940 fuse panel on the firewall is... just sitting out in the open. It seems that there must have been a cover for them at one time. Can anyone share a picture of what a properly dressed set of fuses should look like for this era truck? Thanks - Doug Currently they look like this: http://picasaweb.google.com/lh/photo/Stt-NTjqoM2qj0BCkgW-iw?feat=directlink | | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | That is not original. The fuses on my 41 are on the light switch for the lights, the heater switches for the heater, and in a little inline fuse holder for the radio. | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi, Doug, that is a standard marine fuse panel meant to be screwed to the back side of the dash in a boat. Note: your motor is not stock but the truck looks good and it is still a 6 cylinder. Send away for any cataloge that comes close to your truck, it will pay off on the long run.PS Have fun, Brian
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Mar 2009 Posts: 75 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 75 | Thanks Gentlemen, I think I'll go the inline and on switch route as Kingisomer suggested is stock. I'm lucky enough to have a NAPA and Dan's Classic auto parts ( http://www.dansclassic.com) all within a 5 minute bike ride from my office in Portland -- so I've been making almost daily trips as I figure things out. What would we newbies do without the kindness of your experience? ;-) cheers, Doug | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | My 41 has no fuse except for the headlamp switch. No heater is installed on my truck. But I have located one.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Be careful calling someone an(expert).Because an EX is a hasbeen and a SPURT is a drip under pressure. | | |
