1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 17 New Guy | | New Guy Joined: Oct 2008 Posts: 17 | Hi, I have a 1955 IH truck that is the same size as a 1954 chevy 6400. My original MC was far too gone and new ones are made of unobtainium.
Recently i brought a MC off of a 1979 dodge 350 that has a brake booster attached to it so i could have a temporary MC for brakes. I got it from pull a part and when i went back today i found out that it has front disc brakes. I thought i remember it have drum to drum system.
So even though the MC is a dual diaphragm and was on a disc/drum system, can i still use it with my original brake system? Thanks, Alex
"If you can't fix it with a hammer, you've got an electrical problem."
| | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | If it has internal residual valves you will probably have trouble. The residual for disks is 10psi, 2 for drums. I think your front brakes will drag. I don't know if they can be removed or changed.
Good luck
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 |
