1 members (delky), 86 guests, and 0 robots.
Topics128,094
Posts1,056,064
Members48,433
#585367 10/22/2009 12:52 AM
Hi,
I have a 1955 IH truck that is the same size as a 1954 chevy 6400. My original MC was far too gone and new ones are made of unobtainium.
Recently i brought a MC off of a 1979 dodge 350 that has a brake booster attached to it so i could have a temporary MC for brakes. I got it from pull a part and when i went back today i found out that it has front disc brakes.
I thought i remember it have drum to drum system.
So even though the MC is a dual diaphragm and was on a disc/drum system, can i still use it with my original brake system?
Alex
"If you can't fix it with a hammer, you've got an electrical problem."
Cajunhcm #585741 10/23/2009 4:21 AM
If it has internal residual valves you will probably have trouble. The residual for disks is 10psi, 2 for drums. I think your front brakes will drag. I don't know if they can be removed or changed.
Good luck
Highflyer #585797 10/23/2009 11:29 AM
bore ratios will be off.
