3 members (Otto Skorzeny, walter74, klhansen), 81 guests, and 4 robots.
Topics128,134
Posts1,056,410
Members48,441
Apprentice
Apprentice
Hey folks, got a tough one for ya. I have a 1951 3600 in the garage and am trying to get the vacuum advance to work properly, but first off, I'd figure I'll ask you guys what the engine is since its obviously not the original and I have no idea what it is. Here are a couple numbers I pulled off the block:
Behind the starter:
CoN3E90
or
C0N3E90
Between the distributor and oil vent: 3769716
Another problem I need the correct vacuum advance. I took pictures of the two (original and one I purchased) but the new one is in a straight line from the distributor while on the original the diaphragm is bent 45 degrees out away from the block. Both use brake line fittings, and the problem with the new one is that the advancement/retard hold down bolt hits against the screw to tighten the clamp. If I knew how to post pictures I would or just email me at [email protected] to see the pictures.
Some numbers off the distributor and diaphragm are:
Vacuum Advance:
On the Diaphragm:
Delco/Remy 6 or 9
Above the hole for the hold down bolt/retard scale:
140
On the piece conected to the rubber diaphragm:
566
Distributor:
Underside:
1924230
Inside:
1112403-0E03
I always appreciate all the help and advice as I'm working on my first project.
Thanks.
The distributor was used from 55 thru 63 so an advance for a those years should work. Delco lists a 1116089. I don't see the engine casting number.
The Inliners' casting number links shows the 3769716 as either a 1958-62 235 or a 61-61 235 from a truck.
Hoyt
CoN3E90
CON3 E90
E = May
9 = 9th day
0 = 1960
Tim
Apprentice
Apprentice
Hey folks, been doing some research and still can not find the vacuum advance for my truck, every parts store on and offline have got the one where the diaphragm comes off the distributor parallel the engine not 45 degrees outward towards the fender. Any ideas?
Thanks!
Riding in the Passing Lane
I dont know what all the numbers are but I have been working on some 1936 models & they point towards the fender with a 90 degree el on the tube to the carb. Ican look in some catalogs tomorrow & see what they show.
1972 Chevy c10 Cheyenne Super
On 47-55 truck engine the vacuum advance is parallel to the block; the automobile/passenger engines the vacuum advance is at an angle to the block.
The odd thing is that most Truck Shop Manuals show the automobile vacuum advance unit.
Here are both units next to each other.
If you have the correct base/clamp, this one will work , after drilling out the pivot post and using the original pivot screw.
Tim
All I've ever seen on GMC was the one you refer to as a passenger. It's probably another one of the small differences in Chev and GMC.
Apprentice
Apprentice
Thanks a lot folks! it really helps a lot! Next question; So would that mean the engine is out of a passenger car or possibly just the distributor? or just the vacuum advance and clamp? Also if I wanted to make it more like the truck style, what would I need to replace? I guess I'm not understanding Tclederman's suggestion of drilling out the pivot post and using the original pivot screw.
Thanks again!
I'll post photo but I will not be able to get to my parts until Saturday.
Tim
