0 members (), 53 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#5853 11/28/2004 12:18 AM
Just had Mr. GoodYear tune up my 54 with a 235 Rochester one barrel and auto-choke. Didn't drive it much before tune-up, since tune-up was after valve/head rebuild and new carb. When under load climbing a hill at lower RPMs he seems to ping a bit until the RPMS increase. Is this an octane issue? I run 87 and had 87 in it at time of tune. If so, how do I correct? Timing? He also runs a bit rich?
Thanks (ready for the road)Bruce!
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver
1929 **** Model A Pickup - Restoration
#5854 11/28/2004 10:46 PM
Custom Title
Custom Title
If it's pinging, you either need to run higher octane fuel, or retard the timing slightly. If you have an adjustable vacuum advance, you could take some of the advance out of it.
When does it run rich? If it's at idle, just turn the idle air screw in a bit. If it's at cruise speed, that is only adjustable by changing the jet in the carb.
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
#5855 11/29/2004 12:50 AM
If its pinging after Mr. Goodwrench did the tune up it most likely is because he reset the timing too high. Bring it back and have them retard the timing a little. Most of the goodwrench people today do not know how to tune up these old engines.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#5856 11/29/2004 5:32 AM
H Online: Content
Uhhhh- - - - -he said "Goodyear", which is worse! Those franchise guys only know how to upsell a job, and add on a lot of unnecessary parts and labor. The timing is probably a little early. Retard it a couple of degrees, and see what happens.
