1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#585026 10/20/2009 7:42 PM
I am looking for some opinions for a steering column swap to something more modern for a 57 shortbed GMC. Camaro clip is installed, and I am interested in opinions regarding which is a good column to use. I was told a late 70's early 80's chev/gmc van tilt column is a good candidate. Any input appreciated. Thank You.
Y
Y Offline
The "tilt" column swap will allow you to more room for the belly, turn signal, and a key lock if desired. The vans had a short column, but most columns are easy to "shorten". I've got an S-10 tilt in my 53, and I moved the exit hole over to line up with the Nova rear steer stub.
van column here as well.still ended up shortening it another 5".It was a 75 chevy i used the top stock column drop and a Ididit floor mount for a 55 chevy in my 49..........dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
