1 members (Peggy M),
39
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 35 | I am looking for some opinions for a steering column swap to something more modern for a 57 shortbed GMC. Camaro clip is installed, and I am interested in opinions regarding which is a good column to use. I was told a late 70's early 80's chev/gmc van tilt column is a good candidate. Any input appreciated. Thank You. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | The "tilt" column swap will allow you to more room for the belly, turn signal, and a key lock if desired. The vans had a short column, but most columns are easy to "shorten". I've got an S-10 tilt in my 53, and I moved the exit hole over to line up with the Nova rear steer stub. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | van column here as well.still ended up shortening it another 5".It was a 75 chevy i used the top stock column drop and a Ididit floor mount for a 55 chevy in my 49..........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
