| | | Forums66 Topics128,143 Posts1,056,786 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 75 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 75 | Hello,
My recently purchased '40 1/2 ton has been upgraded to 12 volts with a newer alternator but I just noticed that the (newer looking Delco Remy) Voltage Regulator is not connected to anything (!). I assume things would be better in the long run if I had it connected.
Should I hook it up as per the 1940 shop manual (6v) or does the 12v upgrade require a different approach?
Thanks for any suggestions,
Doug - Portland, Oregon | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If your alternator is internally regulated you don't need the external regulator. If it's not internally regulated this might help.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't know how to tell, or even if you can tell, by looking. If it's a newly manufactured alternator it should be internally regulated. Someone better versed on such things should chime in soon.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Doug,
Great picture. Your alternator appears to have been converted to a single wire unit. You can see the little black plastic cap that covers the tabs on the internal regulator. You need no other regulator for this setup.
If you connect a Ohmmeter across + and - on your coil, a reading of 3 to 4 ohms means it has a internal resistor and no ballast resistor is needed. A reading on your meter of 1 to 2 means you need to stick a ballast resistor ahead of it.
Stuart
| | | | | Joined: Mar 2009 Posts: 75 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 75 | Stewart,
Thanks alot! I really appreciate it. I am at ease knowing that the regulator on my firewall is just decorative... and I'll check the coil ohms ASAP.
Cheers,
Doug | | |
