5 members (Mike in Sycamore, sron48, rfs56trk, Nick in Manitou, 1 invisible), 103 guests, and 4 robots.
Topics128,136
Posts1,056,745
Members48,454
Hello,
My recently purchased '40 1/2 ton has been upgraded to 12 volts with a newer alternator but I just noticed that the (newer looking Delco Remy) Voltage Regulator is not connected to anything (!). I assume things would be better in the long run if I had it connected.
Should I hook it up as per the 1940 shop manual (6v) or does the 12v upgrade require a different approach?
Thanks for any suggestions,
Doug - Portland, Oregon
Ex Hall Monitor
Ex Hall Monitor
If your alternator is internally regulated you don't need the external regulator. If it's not internally regulated this might help.
Thanks Tiny,
Here is a picture of my Alternator - can you tell if it is internally regulated from the outside?
http://picasaweb.google.com/lh/photo/kSdQtVMz3ZZUkPT_R_YxKQ?feat=directlink
And while were at it, Is there a way to tell if my coil needs an external ballast resistor? (I don't see any markings on it from the outside)
http://picasaweb.google.com/lh/photo/uEEBrbgupC_sE_zA-k21PQ?feat=directlink
thanks, Doug
Ex Hall Monitor
Ex Hall Monitor
I don't know how to tell, or even if you can tell, by looking. If it's a newly manufactured alternator it should be internally regulated. Someone better versed on such things should chime in soon. grin
Doug,
Great picture. Your alternator appears to have been converted to a single wire unit. You can see the little black plastic cap that covers the tabs on the internal regulator. You need no other regulator for this setup.
If you connect a Ohmmeter across + and - on your coil, a reading of 3 to 4 ohms means it has a internal resistor and no ballast resistor is needed. A reading on your meter of 1 to 2 means you need to stick a ballast resistor ahead of it.
Stuart
Stewart,
Thanks alot! I really appreciate it. I am at ease knowing that the regulator on my firewall is just decorative... and I'll check the coil ohms ASAP.
Cheers,
Doug
