| | | Forums66 Topics128,151 Posts1,056,990 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 9 New Guy | | New Guy Joined: Oct 2009 Posts: 9 | Help & advise please. I have a 54'/55' 1st series pick up and I picked up a 59' 235 out of a Bel Air (I stupidly sold the original motor awhile back). Does anyone have any advise or knowledge of whether it will mate up to my bell housing and or any other problems that I may encounter. The Bel Air had a automatic so I'll have to get a flywheel. Other than hydraulic lifters are there any other differences in the motors? Thanks, NM | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Water pump location. The '54/'55 1rst still used the high mount water pump. You'll want to use a fan shroud or a pump relocatin plate to prevent cooling problems. As far as bolting up, there shouldn't be any problems, you'll just need the proper flywheel and starter, and i beleive 2 holes drilled in the front plate to allow for the front mount to work.
Bill Burmeister | | | | | Joined: Oct 2009 Posts: 9 New Guy | | New Guy Joined: Oct 2009 Posts: 9 | Thank you. I seem to recall a issue with the water pump when I had the motor changed out before. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If the motor came with automatic trans, you will need to put a pilot shaft bushing in the back of the crankshaft.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | NM,
Will you be setting up the electrical system in your truck as original 6v or changing to 12v?
Tim | | | | | Joined: Oct 2009 Posts: 9 New Guy | | New Guy Joined: Oct 2009 Posts: 9 | Thanks. I'll check into that. NM | | | | | Joined: Oct 2009 Posts: 9 New Guy | | New Guy Joined: Oct 2009 Posts: 9 | It'll be a 12 volt. I converted it over 30 years ago and it worked well. I ran the 6 volt starter on 12 volts and never had a problem. On this new motor I'll probably go with a DUI electronic ignition if it'll work. I have one in my jeep and am sold on the performance and simplicity. I intend to build the motor to 54' vette spec. I haven't researched it much yet though. NM | | |
