0 members (),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | I believe the taller cone on the pressure plate faces the flywheel yes? 235 W/saginaw 4 sp and 11" clutch | | | | | Joined: Sep 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 66 | By 'taller cone' are you referring to the diaphragm spring? | | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | no in the center where the spline is one side stands up taller than the other when laying flat on the bench | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | it has a spline on it? usually called the clutch disc or centre plate if so.
Stuart. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think you are referring to the clutch disc/plate, as Stuart supposes.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It is difficult, I think, to say which side is down without seeing the clutch disc/plate. When you place the disc on the flywheel (on the engine) will the disc lay flat in both orientations?
Are there any markings (words or letters) on either side of the disc?
Tim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | the "taller" side of the spline hub normally goes toward the flywheel. It should also be stamped or marked flywheel side.
| | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | yes I was refering to the clutch disc. Sorry. and no , there were no markings on the disc to tell me which side, hence the confusion. I put it in with the long or " tall" side facing the flywheel. It does lay flat. Just want to make sure. I can't check it by depressing the clutch to see if it will release because the engine assembly is not in the truck but rather on a dolly on the floor. | | |
