Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Wheelie, Pre '68 Dave, Otto Skorzeny, greenie-reddy, TooMany2count), 86 guests, and 5 robots.
Topics128,281
Posts1,058,460
Members48,490
Junior Member
Junior Member
305 V6 w/ 3speed. The clutch has NO resistance to it and about half way down it gets pulled to the floor and you have to pull it back up. I have replaced the master Cyl, slave Cyl, clutch kit, and hyd. clutch line. still does it!!!!!!!
How about the return springs at the fork and the petal?
Riding in the Passing Lane
You may have air in the system. Have someone push in the clutch while you watch the fork. It should start moveing as soon as the pedal does. The linkage may need adjusting. Push the rod all the way back pushing the piston back in the slave cylinder. You should have about a 1/4 in of free play. Also check for free play in the master cyl. push rod. If all that is good you may have something wrong with the clutch its self.
1972 Chevy c10 Cheyenne Super
If it's a diaphragm clutch you might need to make a pedal stop. They will "over-center" if pushed too far in.All you need to do is make sure your adjustment is right,and build some sort of bumper to stop your pedal before it goes far down enough to over-center the clutch.
BTW-diaphragm clutches have light pedal pressure by design,and when used with a hydraulic clutch pedal,even lighter.As long as it releases when you push down and doesn't slip when you let up,no worries.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
