| | | Forums66 Topics128,185 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | I put new weather stripping on my door openings,(64) and now my left door will not shut! I have exhausted every possible adjustment on the hinges,and striker plate to no avail! I have heard that aftermarket rubber pieces are problematic........what's everyone else doing about this? Is there a company that makes these, that actually fit like original? | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Haven't done it YET, but now I'm curious. The right door works O.K.? Where did you get yours?
I wonder how many companies actually make these things, or are they all made in the same place?
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | who cares what those other sites say! just kidding!!! i think mine took a little while to mash down, they shut a lot easier now. good luck. | | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | Thanks for those links Markeb. I got mine at "Classic", and they look really nice, but........they are so thick, that you cant even physically push the door all the way in even with the striker plate removed! Now keep in mind, that without the gasket, the door shuts perfect, and has perfect gaps all the way around! My pins are not worn either as this truck has only 29,000 original miles, and there is no drop when opening the door. I wish I could have saved the originals, but they came off really hard, and I had to cut them, with a razor knife. I too was thinking of the "Steele" brand, but they are pricey, and I need more imput from others. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I too was thinking of the "Steele" brand, but they are pricey, and I need more imput from others. Steele is dependably top quality, many of the repro vendors carry their products - 2 other makers are SoffSeal and Metro Molded parts, usually cheaper ..... ya get what ya pay for Bill | | |
